× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
JCSooner
Tutor
Re: Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
i don't think there is a solution, only temperary solutions that only fail later.  I replaced mind as it was glitchy from day one, then had a major DHCP failure, which is more than likely what you are experiencing.  if you have devices with fixed ip addresses, it will probably work fine, but I had pretty much the same issues.  No WiFi, but it said it was working, static hardwire PC's worked fine, but not any dhcp pc's.  wifi wouldn't transmit.  it was a mess.  Give it up and stop wasting your time being a beta-tester for NG.  Just buy a more reliable router.  Good Luck!
Message 26 of 26
Top Contributors
Discussion stats
  • 25 replies
  • 8745 views
  • 15 kudos
  • 7 in conversation
Announcements
Orbi 770 Series
