× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Mismatch of router band being used
dcopycat12
Follower
RAX75 Firm 1.0.3.98_1046 Win 10 Computer shows connected to 5Ghz channel but the router app shows connected to 2.5Ghz channel Only computer on a gigabit connection, and my max download is 125Mps Did factory reset, and setup 5 and 2.5 as different login creds never get anything greater than 200 for connection Seems like connection stuck in limbo Any ideas? Thanks for your help
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Mismatch of router band being used
Hi dcopycat12,
May you reinstall the Nighthawk app.
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 483 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
