Orbi WiFi 7 RBE973
Reply
Modem to use with RBKE962
tmgrood
Hello,
Has anyone got a suggestion on which cable modem to use with the Orbi RBKE962 system?
I use Xfinity and would rather buy my own equipment.
Thanks
Message 1 of 11
Accepted Solutions
tmgrood
Re: Modem to use with RBKE962
Hey Furry, thanks.
I should have mentioned it in my original post but I need one that accepts Xfinity voice. I do appreciate your quick response. Thank you!!
Message 4 of 11
All Replies
Guru
Check to see if NGs CM2000 modem is supported by XF.
Message 2 of 11
I use the Netgear CM2050V with my Xfinity service.  This is the modem/gateway that includes the analog voice gateway feature that provides our home with telephone services.  Been using it without any problems since last December.
Message 3 of 11
tmgrood
Hey Furry, thanks.
Message 4 of 11
tmgrood
Thanks for your response.
I went ahead and ordered the CM2050V.
I appreciate your help and information.
Message 5 of 11
Guru
Ok, the v version will be the one you want then.
Be sure you use a CAT6A STP cable between the modem and RBR.
Enjoy.
Message 6 of 11
Guru
I've got the CM2000 on xfinity and it works great.
Message 7 of 11
Guru
Missed your reply but the cm2050v is a great option too with needing voice.
Message 8 of 11
tmgrood
Thank you for reminding me about the CAT6e cable. I had read about that being the preferred cable earlier.
Message 9 of 11
tmgrood
Great! Thanks.
Message 10 of 11
Guru
That's CAT6A STP. There is no CAT6e.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 858 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
