- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Netgear AX12 and CM1100 Port Aggregation
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear AX12 and CM1100 Port Aggregation
@kc6108 wrote:
Sorry, this is all I can help with as I'm not familiar with QNAP NAS's... only Synology NAS's.
Very similar - things need to be configured accordingly.
@kc6108 wrote:
Anyone familiar with setting up an LACP LAG between a QNAP NAS and Netgear switch? @schumaku maybe?
That might be a good guess 8-)
Let's see if @jimlenz confirms the LACP 802.3d LACP config on the four NAS GbE ports to start with. Can bring up a TVS-473 with a four port LAG on a MS510TX if required for a test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I went into the NAS and setup port trunking with the 4 lan spots. Once I rebooted, the NAS runs very slow and when I reboot it takes forever. Obviously, something is wrong with the setup either from the NAS or switch side.
When it diid finally login I tried to get back to the network section of control panel to change things back but it continues to say it is loading and wait.
When I connect the Lan cables to the switch do they have to line up 1 to 1, 2 to 2 and so forth? If so, that may be a problem but cant imagine it would be.
I utilized these instructions to setup.
When I reboot and go into qfinder pro it says the NAS has entered an abnormal state and says to contact the system administrator. I can never get to the login page. Definitely something is wrong.
Any advice is helpful.
I tried to disconnect the other lan cables and onlly have #1 but continue to have the same problem. When I disconnect from the switch and connect back into my router, everything is back to normal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sequence doesn't matter.
Operating a Virtual Switch or four native interfaces with the Port Trunking on QTS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would opt for an LACP (803.3ad) trunk - obviously on both ends - instead of going for a static LAG with balanced-xor policy.
This reads similar to the problems we're experiencing with the LAG on the two 10G ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Quickly set-up an LACP LAG over the four GbE ports g1..g4 on the MS510TX and the four GbE ports on a TVS-473:
[~] # cat /proc/net/bonding/bond*
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2+3 (2)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: slow
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: 24:5e:be:XX:XX.X2
Active Aggregator Info:
Aggregator ID: 4
Number of ports: 4
Actor Key: 9
Partner Key: 1000
Partner Mac Address: 10:XX:XX:XX:XX:55
Slave Interface: eth0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: 24:5e:be:XX:XX.X2
Slave queue ID: 0
Aggregator ID: 4
Actor Churn State: none
Partner Churn State: none
Actor Churned Count: 0
Partner Churned Count: 0
details actor lacp pdu:
system priority: 65535
system mac address: 24:5e:be:XX:XX.X2
port key: 9
port priority: 255
port number: 1
port state: 61
details partner lacp pdu:
system priority: 32768
system mac address: 10:XX:XX:XX:XX:55
oper key: 1000
port priority: 128
port number: 1
port state: 61
Slave Interface: eth1
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: 24:5e:be:XX:XX.X3
Slave queue ID: 0
Aggregator ID: 4
port key: 9
port priority: 255
port number: 2
port state: 61
oper key: 1000
port priority: 128
port number: 2
port state: 61
Slave Interface: eth2
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: 24:5e:be:XX:XX.X4
Slave queue ID: 0
Aggregator ID: 4
port key: 9
port priority: 255
port number: 3
port state: 61
oper key: 1000
port priority: 128
port number: 3
port state: 61
Slave Interface: eth3
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: 24:5e:be:XX:XX.X5
Slave queue ID: 0
Aggregator ID: 4
port key: 9
port priority: 255
port number: 4
port state: 61
oper key: 1000
port priority: 128
port number: 4
port state: 61
Looks OK to me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
04 May 2019 21:52:33 UTC+1:00%STP-W-PORTSTATUS: ch1 of instance 0: STP status Forwarding |
04 May 2019 21:52:28 UTC+1:00%LINK-I-Up: ch1 |
04 May 2019 21:52:27 UTC+1:00%TRUNK-I-PORTADDED: Port g4 added to ch1 |
04 May 2019 21:52:27 UTC+1:00%TRUNK-I-PORTADDED: Port g3 added to ch1 |
04 May 2019 21:52:27 UTC+1:00%TRUNK-I-PORTADDED: Port g2 added to ch1 |
04 May 2019 21:52:27 UTC+1:00%TRUNK-I-PORTADDED: Port g1 added to ch1 |
04 May 2019 21:52:24 UTC+1:00%LINK-I-Up: g1 |
04 May 2019 21:52:23 UTC+1:00%LINK-I-Up: g2 |
04 May 2019 21:52:23 UTC+1:00%LINK-I-Up: g3 |
04 May 2019 21:52:22 UTC+1:00%LINK-I-Up: g4 |
- « Previous
- Next »
