× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk AX12
Brillstone
Nighthawk AX12
have a problem with the new router, when to use VPN and FTP?
Has opened ports for ftp and also started the VPn according to netgear's software.
When I try, all ports are closed and VPN does not work?
Also has UPnP in progress.
Is there anything else you should start to get ports open (have done just before on the netgear R8000 and there was no problem there)
Suggestions?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Nighthawk AX12
Hi Brillstone,
I would suggest contacting our support team to assist with your setup.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 3
Brillstone
Re: Nighthawk AX12
It works now, it was my isp fiber switch that was the problem
Thanks
Message 3 of 3
Discussion stats
  • 2 replies
  • 611 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
