× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk AX4: RAX35
stubs
So this model doesn't have a USB port. Readyshare is showing in the network lists.
No way to 'configure' this in the router setups that I can see.
Just how do I shut Readyshare off?
Or is this just another instance of buggy software that seems to be the norm anymore.
Message 1 of 4
Accepted Solutions
rinthos
Luminary
Re: Nighthawk AX4: RAX35
If you see a DLNS or SMB file sharing server as it sounds like you are from the RAX35....
Then that would be very sloppy programming...borderline a bug, yeah.  Short of possibly getting a custom config file to load, Netgear would need to address that in firmware, nothing you can do. 😞
Message 3 of 4
All Replies
Guru
Message 2 of 4
rinthos
Luminary
Message 3 of 4
stubs
Contacted netgear. From the response I received, it is sloppy programming. (Bug)
Maybe I'm the only(first) person that this bothers...
Firmware Version V1.0.3.80_1.0.1
Maybe the will be a fix with the next update.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1950 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
