× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk AX5700 RAX75 Uk power I dafter please please
GROgS01
Follower
Hi
I recently bought a Nighthawk AX5700 RAX75 from the USA. When I purchased i did some searching round and found that the power adapter was between 100v and 240v. Unfortunately it is only rated between 100v and 120v. The Part number On the existing power adapter is “332-11506-01”. Could anybody provide me with the UK specification and contact information where I can purchase one from please. Thanking you all in advance
Greg
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Nighthawk AX5700 RAX75 Uk power I dafter please please
Hello GROgS01,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Message 2 of 2
Discussion stats
  • 1 reply
  • 533 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
