- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AX6 AX4300: Macbook pro can detect but can't connect with password
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi community,
I have some issue with wifi connection to ask since my premium support already expired.
I bought Nighthawk AX6 6-Stream AX4300 WiFi Router in August, 2020 as the second wifi router in the house. And I found my macbook pro couldn't connect to the Netgear RAX45 Router while it can connect to the Verizon FiOS Quantum Router. But my iphone 11 Pro Max and my wife's Macbook Pro can connect to both routers.
I already updated the RAX45 router's firmware and my macbook pro with the latest updates. I tried to delete both Macbook's wifi saved passwords and reconnect them to the both routers. The result is the same: my iPhone and my wifi's Macbook can connect to the bother routers, but my Macbook couldn't connect to the RAX45 router.
The error message says: "Connection Failed."
I checked the Access Control in Netgear Router admin page, and Chose "Allow All New Devices to Connect" and saved the setting. But no help.
What's wrong? Can anyone help me on this?
Thanks a lot in advance~!
Simon
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AX6 AX4300: Macbook pro can detect but can't connect with password
Is the RAX45 in access point mode?
Having 2 routers in router mode can cause issues on a network.
https://kb.netgear.com/30186/What-is-Double-NAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. I think I make it Double NAT.
Let me try to set it to Access Point mode and get back to you.
Thanks,
Simon
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried a simple factory reset and reinstall of the RAX?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reset it in early January since I got some problems. And then found this connecting issue.
Should I do it again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Never hurts to start fresh.
If its not to much of a pain, you could even try using a different ssid/password in case its an issue with the macbook not forgetting the network properly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
