× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX45 Starts Broadcasting SSID when I use the Nighthawk mobile app
gtdurham
Follower
I have setup my Nighthawk router to not broadcast my SSID. If I use the Nighthawk mobile app either on my iPhone or android tablet, it reset the SSID  on my 5GHz network to broadcast the SSID. Any suggestions as to why it's happening and what I can do to resolve this issue?
Thanks
Message 1 of 4
microchip8
Master
Re: Nighthawk RAX45 Starts Broadcasting SSID when I use the Nighthawk mobile app
Don't use crappy apps
Routing: NETGEAR RAX43 - Firmware: v1.0.15.128 (1 Gbps down, 40 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2) / 2x NETGEAR PL1000v2
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 4
Great idea, but what if you want to use remote management?
Is that still possible without the apps? Ever tighter security means that these things get harder.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 3 of 4
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Message 4 of 4
Discussion stats
  • 3 replies
  • 582 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
