- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RAX80 Ethernet Not Working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a netgear nighthawk RAX80 and I have an audio reciever (a marantz SR6008) and its connected via ethernet to the router. However, it's not getting a connection. When I run the test I get an error that says "No internet connection check your routers settings" but I have no idea which settings it could be. It shows a diagram with the reciever connected to the router via ethernet which is marked with a green check, and then the router connected to the internet which has a red x. So my question for you is can you think of any settings that would be blocking this on the config page? The device has a MAC address and an IP address so I'm almost 100% it's not the device
FIRMWARE: V1.0.1.70_1.0.30
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RAX80 Ethernet Not Working
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's an xfinity dual band wifi 802.11ac
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's a wifi specification, not a model number.
As @plemans says, this would make it a modem/router.
How you fix the problem depends on whether you want to disable the router bit of the unnamed modem/router or the RAX80.
There are other options, but they are the easiest.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
