× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Port forwarding settings disappear RAXE500
akhan999
I noticed by PBX server was no longer visible outside of my home network.  Looking further into I noticed Port Forwarding / Port Triggering settings were no longer visible in the Netgear UI.  I restarted the server and they reappeared.  Only to disappear again the next day. This seems like a BUG and I see similar issue on other routers, sounds like something Netgear can't figure out?
It's a big problem for me as I can't use my PBX system outside my home.
Anyone got a solution here?
Message 1 of 4
Guru
Re: Port forwarding settings disappear RAXE500
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is uPnP disabled while the PF configuration is enabled?
Try the PBX service device in the DMZ on the RAX instead of using PF configuration?
Message 2 of 4
akhan999
Hi,
  • Firmware V1.2.13.100_2.0.54 Maybe this caused it worked fine before this.
  • ADTRAN sdx611 GPON ONT
  • Using the cable they provided
  • UPnP is enabled
  • Not keen on using DMZ.
Message 3 of 4
Guru
Disable uPnP if you have any PF configurations enabled...then check.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 922 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
