- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX 35 keeps disconnecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently statred having issues with the router randomly disconnecting all my devices then a few seconds later it reconnects. There is no pattern happens at all times fo the day and neve rhad issues until the past 2 weeks. I checked the the firmwire (1.0.3.62_1.0.1) and i belive its the most recent. I have done a factory reset twice and it is ok for a day or two then the issues start again. ANy recommendations?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX 35 keeps disconnecting
Hello juann24 - I have sent you a message. Please check your inbox.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue where it'll randomly disconnect and I'll have to unplug and reboot about 4-5 times a day, extremely inconvenient and to be honest not what I expected when purchasing a $100 router. Can you help me out?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same thing is happening here with this model. Constant disconnects where the wireless disappears and a reboot of the router is required for the wireless to show back up.
This has the newest firmware as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also have the AX4-RAX35 and the wifi stops broadcasting every few hours (this has been happening for the past month, maybe after the latest firmware update). The lights on the router seem to not change or indicate any problem. The connection seems relatively stable (based on my camera continuing to work) when I am away from the house, but the broadcasting stops when I try to actively use the interent on my phone or other device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have at&t modem 300 mbps plan.
Netgear asking $99 for diagnosis when my hardware warranty is still there!
Can any suggest any settings?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The disconnect issue with the RAX35 / RAX40 router looks to be related to the 1.0.3.80 firmware. I haven't found a way to report a firmware bug to Netgear. Perhaps the issues posted in these Netgear community discussions are being written up as bugs for the QA team to review and developers to correct.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think the RAX35 and RAX40 routers may use the same firmware. I see in the "RAX40 Firmware 1.0.3.80 Crash/Bug Log" discussion they are testing a beta firmware for the RAX40.
I recently had all of my 5Ghz devices disconnect from the router and wouldn't reconnect until I rebooted the router. 2.4Ghz connections didn't have an issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same disconnet problem since a few months ago.
How should I download this to help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I noticed the link you post is for RAX75. Will that firmware work on RAX35? If yes, what is the instruction to update to my RAX35?
Thanks
@mdwpilot wrote:
https://www.netgear.com/support/product/rax75.aspx#download
