- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX-75 Incorrect time,
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have RAX75 with firmware V1.0.3.98_1.0.46.
I noticed the router is not maintained by router. Netgear support sent me some NTP server list and i updated the router. Time is synced every time i reboot then it stays at the same day+hour+minute. Its not advancing. I see that same time stamp after hours or days. The router log time stamp is also wrong because there is no clock running inside. Netgear support asked me to downgrade firmware and factory reset. I am trying to avoid a factory reset because i dont want to set up client ips from scratch. Any one faced same issue of time in router? Any known solution other than factory reset ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX-75 Incorrect time
Same problem here with my rax80 afer installing V1.0.3.98_1.0.46
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX-75 Incorrect time,
Hello aant & AB3458,
May you send me a private message with your email address and serial number. We currently have a trial firmware that may address your issue.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX75 S/N 6271967TA0548
Using pool.ntp.org with GMT-06:00 timezone as NTP server or the Netgear server, the router retrives incorrect time and date (as of Sunday, 30 Aug 2020 13:56:43 CDT the rouiter shows "Wednesday, 12 Aug 2020 15:18:28") and never advances from that day, hour, or minute, but the seconds vary between 18 and 47 on repeated entry to the NTP page.
New firmware is required with correct NTP routine!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue. May I PM you my serial number as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue... Firmware on V1.0.3.98_1.0.46
Router time is about 11 hours behind. See attached screenshot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear pulled that firmware from their site. I actually downgraded back to .88
So far everything is good after that. I hope they get this fixed soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@steviev1 wrote:Netgear pulled that firmware from their site. I actually downgraded back to .88
Looks like they pulled back the firmware only for RAX-80.
RAX-75 still shows 1.0.3.98.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Probably should be pulled for the 75 also.
Anyone from Netgear care to comment on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I downgraded to the V1.0.3.88_1.0.41 at 1540 CST and the time is now working perfectly. Hopefully it also fixes the intermittent issues I have been having with the wifi connections becoming non-responsive when the system reloaded itself.
It's kind of ridiculous Netgear downgraded the RAX80 but not the RAX75... though I suppose I shouldn't be too surprised considering I can't even log in with the Nighthawk app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
(To be completely fair, however, I *should* note that now that the router has the correct timestamp it also seems to have fixed the Nighthawk app immediately claiming you have attempted to login too many times incorrectly without even attempting to submit a login request.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had the exact same issue with the RAX80.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
