× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX120 Slow Speeds Wired
ehmabe
My ISP service is 200 mbps DL . Currnelty with the RAX120 my speeds are around 90 DL. When I bypass the router and direct to the modem I am running 226 Mbps.  This happens to the firmware 122 and up.
Any ideas what I settings I need to set. When I used the Qos the speeds drop to less than 20.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 8
Guru
Re: RAX120 Slow Speeds Wired
are you testing wired/wireless?
Have you checked the cable? it seems like you're dropping from a gigabit connection to a 100mbps connection. You can check this by logging in and going to advanced-----show statistics.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
If its showing that port at 100m and not gigabit, then its time to check cables/modems/ports.
Message 2 of 8
ehmabe
I am testing wired. When connected direct to my modem sb6190. My speeds are over 200 mbps
Message 3 of 8
Guru
and what do the port statistics show?
Message 4 of 8
ehmabe
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
5G Ethernet Link Down 0 0 0 0 0 00:00:00
WAN 100M/Full 617938 1142419 0 67067 544031 00:08:24
LAN 1 1000M/Full 899947 503200 0 431181 46258 00:45:35
LAN 2 Link Down 00:00:00
LAN 3 1000M/Full 00:45:35
LAN 4 1000M/Full 00:45:35
2.4G WLAN b/g/n/ax 1147M 8629 5253 0 2485 305 00:26:11
5G WLAN a/n/ac/ax 4803M 280762 130203 0 96113 5208 00:26:06Port
StatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
5G EthernetLink Down0000000:00:00
WAN100M/Full617938114241906706754403100:08:24
LAN 11000M/Full89994750320004311814625800:45:35
LAN 2Link Down00:00:00
LAN 31000M/Full00:45:35
LAN 41000M/Full00:45:35
2.4G WLAN b/g/n/ax1147M862952530248530500:26:11
5G WLAN a/n/ac/ax4803M280762130203096113520800:26:06
Message 5 of 8
ehmabe
Should the WAN status be at 100m
Message 6 of 8
Guru
There's no way to "set" the port speed. Its auto negotiated. so I'd be betting on the cable or port having issues.
I'd start with checking those.
Message 7 of 8
ehmabe
Thanks
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2050 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
