Orbi WiFi 7 RBE973
Reply
RAX15 can stream YouTube TV on ROKU TV but not Amazon Prime or Netflix video
metrosport
can stream YouTube TV on ROKU TV but not Amazon Prime or Netflix video.. all work on my other router but get the same message that video is not available now on netgear
Message 1 of 8
Guru
Re: RAX15 can stream YouTube TV on ROKU TV but not Amazon Prime or Netflix video
What modem are you using? (model number)
Firmware on your RAX15?
Message 2 of 8
metrosport
Frontier
Arris.. NVG4438
Message 3 of 8
metrosport
firmware.. up to date
Message 4 of 8
Guru
That device is a modem router combo device. Putting you in a double nat which can cause issues with some streaming services.
options?
1. put the arris in modem only mode. contact your isp or arris about doing that.
2. put the netgear in AP (access point) mode. This disables routing features on the netgear and leaves the arris managing routing.
3. put the netgear's ip address in the Arris's device DMZ. again, consult your isp or manual for arris to do this.
Message 5 of 8
CaptainB
Tutor
I have a RAX15 and it is definately not a modem/router, it is a wireless Router.  I have the CM1000 modem connected to Comcast cable and am getting ~400Gbps down and ~18 Gps up as measured by Comcast.  I have had no problems watching Netflix or streaming XM music with these two devices.
Message 6 of 8
Guru
Did you read the posts?
The OP has a Arris NVG4438 which is a modem/router combo device.
They don't have your setup with RAX15 and a cm1000.
so there wasn't much/any benefit from your post.
Message 7 of 8
CaptainB
Tutor
You're right, I didn't read and comprehend.  I guess that I'm more of a full sentence type of guy.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1609 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
