- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RAX200 1.0.2.98 Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 1.0.2.98 Firmware
Loaded V1.0.2.102_1.0.56. NTP time now working but but stuck at Date Line West time. Cannot set to local time zone or for Daylight Saving. Reverted back to V88. Did a hard reset and reloaded V102. Still unable to set to local time zone or for daylight Saving. Reload V88 config file on top of V102. Time now set to Local Time zone but GUI still indicates that router is set to Date Line West and unable to change. Left router in that state. Probably now going over to ASUS. At least their update releases appear to clear bugs rather than create new ones!
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI, I went to the Asus GT-AX 11000 and it works great no problems what so ever. I us the RAX200 piece of **bleep** as an Access Point now. An expensive AP what it does work well as the AP. I gave up on Netgear 2 firmware updates ago.
Good Luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Many thanks for the advice. I'll look out for the router.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What you describe is exactly what occured to me with the previous firmware. I gave up on the router and returned because I could dedicate more time for a correction. If it happens again, because it did happen as you describe with your slow downs to me on all streaming devices on wired connections and internet speeds on wifi as well and with the old firmware after about a week... check your internet connection properties and see what the connectivity speed is. Mine went from a gigabit connection down to a 100 kb connection. I can only assume all devices suffered the same issue causing such massive slow downs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem I experienced, which this version of the firmware fixed (102_1.0.56), was that the time on the router was locked to the date/time of the last reboot. This meant every entry in the log had the same date/timestamp, making it nearly impossible to read the log. That problem has been fixed in this latest update, and my router has been stable since the update. However, others have experienced problems after installing it, therefore YMMV.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
