× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX200 Router not found with Nighthawk Android app after V1.0.2.88_1.0.50 update.
Nightcat
Updated the nighthawk android app and routers firmware to V1.0.2.88_1.0.50 and im getting router not found messege help.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 15
Christian_R
NETGEAR Employee Retired
Re: RAX200 Router not found with Nighthawk Android app after V1.0.2.88_1.0.50 update.
Hi Nightcat,
If you haven't done so already, may you perform a factory reset on the router after a firmware update.
Christian
Message 2 of 15
Nightcat
@Christian_R wrote:
Hi Nightcat,
Christian
Did a factory reset and still says router not found, even when choosing setup a new device.
Message 3 of 15
Christian_R
@Nightcat - Thanks for confirming. May you provide me with the current Nighthawk app version you have installed on your android device.
Thanks,
Christian
Message 4 of 15
RajaDaja
Luminary
Log into your router thru web browser:
router login.net or routerlogin.com
If you haven’t, set your router up.
Look to enable; Remote Management.....
under advance tab or admin
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router, RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 5 of 15
Nightcat
Android app version 2.5.4.1036
Message 6 of 15
Nightcat
@RajaDaja I did enable remote management it still won't connect for me.
When i click the apply button when enabling remote management  the router doesn't reboot or confirm that its on.
Message 7 of 15
RajaDaja
Luminary
Go off wi-fi then open nighthawk app. As the app loads at the bottom click on the purple banner connect remotely or to that affect.
Message 8 of 15
Nightcat
@RajaDaja
Turned off wifi and tried connecting remotely through 5g network and it still says no devices detected.
Message 9 of 15
RajaDaja
Luminary
Wow! One final thought...... Uninstall the App if you haven’t already and reinstall. Good luck!👍🏼
Message 10 of 15
RajaDaja
Luminary
I believe the app is faulty. Since the app update I noticed it takes longer to detect router when opening the app and sometimes the login process glitches and takes you back to the login screen. Any who, I thought this might help to understand you situation.
Message 11 of 15
Nightcat
@RajaDaja
I reinstalled the app and it still says router not found. If there was an option to connect using lan ip it would be better.
The problem is it won't connect at all for me I'll try going back to a previous version and see if it will work.
Message 12 of 15
Nightcat
Okay so i tried all of the previous versions and non of them could find the router. Only version 2.4.25.962 would work properly and find my router.
Message 13 of 15
RajaDaja
Luminary
I don’t think it your devices. It’s the App. Hang in there! 🤬
Message 14 of 15
Mad6913
I bought new RAX200 router, would not connect to internet at all, factory resets, modem power cycles, etc
Found out through Netgear
Tech Support,
1. Factory default router
2. Power cycle Modem
3. Reboot Router
4.must login to router directly, with hardwire to port 2,
5.login Routerlogin.net
Run through initial set up, once logged into router.
6. Go to Ethernet
7. SCROLL DOWN TO BOTTOM
8. make sure it states "Use Computer Mac Address"
9. APPLY
10. internet issues should be resolved,
11. Go to Nighthawk APP
12. Complete set up of router on App.
Hope this helps..
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 3286 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
