- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX200 and readyshare PRINTER
- Mark as New
- Bookmark
- Subscribe
- Permalink
I upgraded my router from a nighthawk R7000 which supported a USB printer. (READYSHARE). It appears th RAX200 only supports USB storage devices. Is that correct and I'm out of luck?
Also, I cannot determine how to stop the WPS button on the front of the router to stop blinking without turning off ALL the LEDs.
And one last question; Will a EX7000 wifi extender work with the RAX200 router?
Thank you whoever has the answers.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi hkenr,
The RAX200 currently does not support ReadyShare. In regarding to the WPS button, I would recommend contacting our support team using the link below as I've seen other threads of users reporting a similar experience.
The EX7000 should work with the RAX200 router and you should have no issues.
https://www.netgear.com/support/default.aspx
Christian
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi hkenr,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 and readyshare PRINTER
Thank you for your reply.
But contacting NETGEAR SUPPORT directly is almost impossible. They provide NO email support at all, so you get a case number, call and hold, hold, hold....That's the reason I went the community route.for the issues. The EX7000 extender installed without a problem by the way, so thank you for that.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
