× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX200 enforce FAN to operate
HCTomTom
Follower
Dear All,
Do anyone of idea how to enforce the FAN of RAX200 to run?  Some said if will just run when boot up or in high temp, but I found it just not running while the router becomes hot.
So:
1. anyway to force FAN running?  checked the debug.htm in RAX200 console there are no FAN control.
2. is there anyway to check the current temperture of RAX200?
Regards..
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Guru
Re: RAX200 enforce FAN to operate
If you're wanting a constantly running fan, I'd strongly encourage you to look at a laptop cooler. they're not very expensive, designed to run long term, and if it does burn out due to always on, its easy to replace. Versus if you turned the one on in the router and it burns out, its more expensive to replace and you have to crack the case open.
You can take a look at this thread.
https://www.snbforums.com/threads/netgear-router-hidden-pages.56118/
Message 2 of 3
rlaroch1
Guide
My solution. I added tall fee
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2584 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
