× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX35, I want to change region.
Lecdia
I live in Korea, and this time I bought the RAX35 distributed in the US from Amazon.
There is no problem in using it, but I want to change it to the Korean region, but I can't change it because it's locked.
Is there a way?
Message 1 of 4
Guru
Re: RAX35, I want to change region.
The region is locked in certain regions (like north america).
You used to be able to telenet in and use the burnsku command (google it) to be able to change the region.
Message 2 of 4
Lecdia
I want to enable telnet, but it doesn't work. How do I do it?
Message 3 of 4
Guru
Telnet support has been pulled from a  lot of products. Not sure if that device supports it or not anymore.
You might not be able to.
You can try using this option:
https://github.com/insanid/NetgearTelnetEnable
Message 4 of 4
Discussion stats
  • 3 replies
  • 1422 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
