× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX35 — Nighthawk AX4 4-Stream WiFi 6 Router is stuck in bridge mode
NathanTPerk
I turned the bridge mode setting on for my RAX35 — Nighthawk AX4 4-Stream WiFi 6 Router. Now I cannot access that admin panel.
I have tried the factory reset, but when I try, none of the lights change and it does not under go the reset process.
How do I access the panel in bridge mode?
Will turning off bridge mode allow me to reset my router?
Message 1 of 8
Guru
Re: RAX35 — Nighthawk AX4 4-Stream WiFi 6 Router is stuck in bridge mode
When you're resetting, are you pushing and holding reset for up to 30 seconds while powered on?
Message 2 of 8
schumaku
Guru
This could be very different things, on some routers, this can be about routers (typically xDSL or cable router) not do routing/NAT, so another router behind can get the public IP address to it's WAN/Internet port, on different context this could be configuring two devices into wireless bridge mode.
Impossible to guess what the reason was for such a config, and what exactly was configured.
Well possible this device should have got a LAN IP address. This isn't reachable using the DNS tricks like routerlogin . com or just call the default LAN IP. If cabled correct, and the environment is working, a DHCP server will still assign a LAN IP o that subnet.
Nighthawk AX4 4-Stream AX3000 WiFi 6 Router Model RAX35 User Manual
"Tip: If the router is in access point mode or bridge mode and you do not know the IP
address that is assigned to it, first try to use an IP scanner application to detect the IP
address. (IP scanner applications are available online free of charge.) If you can detect
the IP address, you don’t need to reset the router to factory default settings."
Message 3 of 8
NathanTPerk
What do you mean I don’t have to reset it to factory settings if I find the ip?
I found the ip when I used an ip config command or on my Mac when I login into the network.
When I use any web browser to try and open the admin panel, it still doesn’t work. Do you have any suggestions for an ip scanner on macOS. Angry IP Scanner does not work because it’s developer certificate expired.
Message 4 of 8
schumaku
Guru
With this WAX35 in question connecting to the network in whatever way - to another device with a link to your LAN and the default gateway of the unknown other router, yes.
IP config shows the address(es) of the adpter(s) on your MAC, as well as the default gateway, the operational router LAN IP typically.
Use ... crystal ball?
Message 5 of 8
NathanTPerk
“With this WAX35 in question connecting to the network in whatever way - to another device with a link to your LAN and the default gateway of the unknown other router, yes.”
1. Yes, but this still isn’t getting me to the admin panel. I need to access the admin panel to turn off bridge mode. Is there another way?
2. Sorry I should have made it clearer, I used windows ipconfig command and on MAC in network preferences you can easily find ip of network your connected to.
3. What is crystal ball?
Message 6 of 8
NathanTPerk
Yes. I hold it down and none of the lights change to indicate a factory reset. I have held the button down for every increment of time you can think of.
Message 7 of 8
schumaku
Guru
Still no idea on how the WAX35 was operated and configured before to provide a workable environment.
This gives the PC resp Mac adapter IP, the default gateway IP (which isn't the WAX35 unless I'm missing something), the subnet mask.
https://en.wikipedia.org/wiki/Crystal_ball A crystal ball, also known as an orbuculum or crystal sphere, is a crystal or glass ball and common fortune-telling object. It is generally associated with the performance of clairvoyance and scrying in particular.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1681 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
