× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX40 — Nighthawk AX4 4-Stream WiFi Router
aqualita
my RAX40 — Nighthawk AX4 4-Stream WiFi Router switches off the internet all the time after the latest firmware update,  what to do
1). windows 10 Home 64 bit
2). Fastvareversjon V1.0.3.80_1.0.1 ( router)
regards from
Tore Braathe
Norway
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
Guru
Re: RAX40 — Nighthawk AX4 4-Stream WiFi Router
anytime there's an issue after a firmware upgrade, a reasonable first step is  factory reset.
If that doesn't help, then I'd downgrade the firmware to the older version. Maybe the newer one introducted a bug in your device.
Once downgraded, disable auto updates so it doesn't automatically go back to the problem version.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 689 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
