- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX40 cannot connect to routerlogin.net
- Mark as New
- Bookmark
- Subscribe
- Permalink
Somehow I am blocked out of my router. I have internet connection, Nighthawk app says router is offline, but it is working. Phones and laptops will only connect to NetGear wifi extender as of just a few days ago. Web broswer will not connect to routerlogin.net (Brave) Firefox redirects to NetGear main page. What am I missing. Hacked ? Help...
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
With a little help from my friends. Back up and running, making sure I utlize Armor and cataloging id's then lock down the routers from new loggins.
Thank you for the help !
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX40 cannot connect to routerlogin.net
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So it appears I have been attacked by an outside computer that has taken over my router login found on my network -EM-87F12R2, at the very bottom of this snip pic. What are the next steps ? Will the factory reset button work ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
IS there a wired device on your network that has the host name?
Can you access the routers web page at 192.168.1.1?
Factory reset the router. Disconnect ALL wired devices from the back of the router accept for your 1 wired PC that you'll be working with. Walk thru the setup wizard at 192.168.1.1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
IS there a wired device on your network that has the host name? NO
Can you access the routers web page at 192.168.1.1? NO
Factory reset the router. Disconnect ALL wired devices from the back of the router accept for your 1 wired PC that you'll be working with. Walk thru the setup wizard at 192.168.1.1. - Will do.
This is the second time I have had trouble, first time was a ssid name change I did not do, and reset everthing. This time I got locked right out. Looking for vunerability-s to patch wifi alram system ? They say NO. I used a unique and good password. There is allot of wi-fi in this 150 plus community. Strange things going on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
