- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX40 only connects via IPv6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have the RAX40 v1. When it reboots I can see that it successfully gets an ipv4 address from my modem (Arris - Spectrum internet), but my connected devices can only communicate via ipv6. I will typically start a ping to yahoo and it responds on ipv6 with no issues, but if I direct it to ipv4 it dies. The router shows an ipv4 address from the modem.
I am currently on Firmware 1.0.3.88_1.0.1, but I have had the same issue on 1.0.3.80_1.0.1.
Troubleshooting I have tried:
Disabling ipv6 on the router, rebooting - same issue.
Release/renew address from router to cable modem - same issue.
Change ipv4 DNS providers on router (typically use 8.8.8.8 and 9.9.9.9, but have tried using Spectrum's automatically provided DNS) - same issue.
Have tried multiple devices (I have roughly 20 connected - Windows 10, android, samsung tvs, rokus, etc) - all have the same issue.
Have tried plugging in directly to the router - same issue.
IPv6 capable web pages (yahoo.com for example) work perfectly fine.
I have rebooted the modem and router multiple times - both physically and virtually - same issues.
There is nothing in the logs that seems to alert me to a DNS issue or an IPv4 issue from Spectrum.
After an indeterminate amount of time - usually somewhere from 15 minutes to 45 minutes - ipv4 eventually starts working with everything connected.
Thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX40 only connects via IPv6
Hello krebs119,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Christian,
Unfortunately I've had this router for over 1 year now. Any other help you can provide?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Netgear folks - do you have any other suggestions?
