- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX50 - issues with 1) network priorities and 2) blocked sites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought a Nighthawk AX50 to replace my R6300v2 - love the speed increase. Not much of a significant improvement on wifi coverage though.
Anyway, I have a couple of issues.
1) Cannot set network priorities.
After applying the settings and the router rebooted, the priority remained the same - some stuck on High, some on Normal, and I want to set my NAS on highest priority.
I found an old post on another router suggesting to try using a different browser. I tried Microsoft Edge (new), Google Chrome, Firefox but nothing has changed.
2) Block sites
It will only block connections to sites if the device is using wifi.
Is this by design? What about devices connected to the router via network cables?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX50 - issues with 1) network priorities and 2) blocked sites
Hello Chanelmusic5,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
