× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX70 update with 1..0.5.108 firmware always reboot automaticly
I update my RAX70 nighthawk Wifi6 router to the latest firmware 1.0.5.108, but after one or two days, it will be automaticly reboot by itself, I try to Reset equipment and reset all parameter, but the problem still. I have to degrade it with 1.0.3.92 version to keep the stability.
Hope offical could be fix this problem in new version.
Message 1 of 11
Accepted Solutions
Guru
Re: RAX70 update with 1..0.5.108 firmware always reboot automaticly
Thanks for posting!
Glad a downgrade fixed the issue.
Hopefully a mod or engineer sees this so they can be aware of the issue.
Message 2 of 11
All Replies
Guru
Thanks for posting!
Message 2 of 11
Thanks for care about my issue, will keep focus on this
Message 3 of 11
Are there nobody encounter this issue? Or just because RAX70 router is minortrity?
Message 4 of 11
Today the new version firmware has been realeased, not sure if this has been fixed the issue, will test during next days
https://kb.netgear.com/000064287/RAX70-Firmware-Version-1-0-10-110?language=en_US
Message 5 of 11
Guru
Let us know what you find out.
Message 6 of 11
Will do
Message 7 of 11
After three days continu test, this new version firmware has fixed the issue perfectly, and also provide stable connection with low delay time.
Message 8 of 11
Guru
Glad its up and working well for you!
Message 9 of 11
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 10 of 11
Thanks for the guid, appreciate for you immediately action to fix this problem, have a nice day!
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3127 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
