× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX75 keeps disconnecting the 5GHZ after and before firmware 1.02.76
PhillipJ
Went through tech to reconfigure and updated firmware 1.02.76 on 4-21-2020. I connect with the 5G and it disconnects every 2-3 hours and then comes back on itself. I have a Xfinity networks.. Before using this Router I had a mesh network that NEVER once drop my connection but it was a little slow but never had a drop connection. It is frustrating as talking ton Skype or WebEx meetings I drop call. The mesh network I had is over 3 yrs old and might go back using it. This is a terrible lack of quality. Anyone had problems. I was advise to change channels on the 5G by the tech.. I still am disconnecting. The 2G somehow also gets disconnected sometimes. Case #42600598
Message 1 of 5
PhillipJ
Re: RAX75 keeps disconnecting the 5GHZ after and before firmware 1.02.76
I cannot always do a reboot 2-3x a day... other routters I had.. there was never any need to do that
Message 2 of 5
Christian_R
NETGEAR Employee Retired
Hello PhillipJ,
May you try disabling AX mode. Has support been able to follow up on your case?
Christian
Message 3 of 5
PhillipJ
How do I do that? It is crazy
Message 4 of 5
PhillipJ
If I disable this feature then what is the point of paying so much to get this router?? Doesn't make sense.. will it make this router then unable to reach my 2nd floor or limited the distance it can reach?? Please advise.
Message 5 of 5
Discussion stats
  • 4 replies
  • 1094 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
