× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 Half Speed
vietp13
RAX80 Half Speed
After a firmware update or a router rebooty wired speed goes from 940mbps to 450. I would have to reset the router and configure the setting as I did before to get my speed back to normal. This happens when the power goes out as well. Is there anything I can do to prevent this or am I stuck with this as a resolution?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 8
ChAKiBrOs
Guide
Re: RAX80 Half Speed
I'm having same problem here, it seems speed capped after time sync with NTP sever.
Message 2 of 8
staindwithink
Rax80 Mine does the same thing daily...reset the modem every day so annoying  1 gig down to 500 reset and get my gig back
Message 3 of 8
Christian_R
NETGEAR Employee Retired
Hello Everyone,
Would you mind providing me with the firmware version your RAX80 is currently on? We recommend ensuring your device is on the latest firmware.
Christian
Message 4 of 8
staindwithink
I had the newest verison and the link dropped over 60 times a day from the ONT.  So annoying!  I just downgraded to .40 hopefully its more stable although now I cant get a gig at all.  Just 500 megs.  Hasnt dropped from ONT yet though.
Message 5 of 8
vietp13
The firmware I'm using is v1.0.1.64_1.0.27
Message 6 of 8
ChAKiBrOs
Guide
I have tried different version of firmware, speed can be resumed after factory reset or enable QOS, but it capped after time sync.
Message 7 of 8
Christian_R
Hello Everyone,
Thanks for confirming. For those who have not reverted to a previous firmware version, I'm curious to know the outcome once you're able to.
Thanks,
Christian
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1727 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
