- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 New Firmware V1.0.6.138_1.0.76 = No internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just wanted to give a heads up on my experience. I updated to firmware V1.0.6.138_1.0.76. The update happened with no issue and my status said it was connected to the Internet but there was no internet! I was able to ping 8.8.8.8 but still no go.
I rolled back to Firmware Version 1.0.5.132 and had no issues.
Looks like there might be a fault with V1.0.6.138_1.0.76
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 New Firmware V1.0.6.138_1.0.76 = No internet
After you updated, did you try a factory resets?
Its usually the first step we recommend after a firmware change if there's issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Definitely not going to erase all my settings. So no I did not do that. Rolling back fixed the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Next time make a backup and try the factory reset.
Fixes a lot of issues after firmware changes.
glad you got it working though.
You might mark it solved so others aren't still trying to fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved by downgrading is not solved. Factory reset is a bit basic tbh...
- Mark as New
- Bookmark
- Subscribe
- Permalink
so not sure what you're expecting here. You don't want to factory reset after an update (which is recommended if there's issues) so you choose to downgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
“I just wanted to give a heads up on my experience.“
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same experience. After upgrading to the 138 firmware, it completely killed my internet connectivity. I called support, and basically got all the stupid router setup questions. Having owned nearly 10 different nighthawk routers and experience updating them all and setting them up in a home with VPN tunnel and 40 active devices I’m not oblivious to setting up a router. I would up have to return back to the 132 firmware myself. I sort of shocked they didn’t take this firmware update down as it had to of generated thousands of calls as a result of the failure it has created.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was a factory reset performed and setup from scratch after loading v.138?
Did you power OFF the ISP modem/ONT as well for 1 minute the back ON then complete the setup wizard?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did not perform a factory reset. All the updates I have done previous with this router having owned it for several years did not require it, nor did it cause an issue. I have too many modified settings to go this route as it would take me some time to redo all the setting and modifications. The 132 firmware worked well so downgrading back wasn’t a problem for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset next time. Sometimes a factory reset IS needed.
Also one should have a back up configuration saved to file for save keeping. Saves time if a reset is needed.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reset maybe needed for those that see this problem:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 Firmware V1.0.6.138_1.0.76 = No internet
The "solution" is not a solution....
Version 1.0.10.140 is the new one out.
- Fixed a bug where after enabling Open VPN function, DNS resolution function will become abnormal.
So also kudos to the person that scrubbed me from my own post and trying to hawk solutions that are BS!
Has anyone updated? I have not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is anyone still seeing these issues on the latest firmware?
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
