- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Separating or Disabling 5Ghz and 2.4Ghz on Mesh WiFi 6 System
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk Mesh WiFi 6 System AX1800 (model number refused to type in, above)
My problem feels simple, though the solution seems elusive.
I have a houseful of Amazon Echo devices (along with several "smart" switches, a Ring doorbell, a MyQ garage door). I like to play music on ALL of the speakers at the same time, and was able to on my older router. I bought this new router in order to reach the garage door more effectively. After weeks of frustration, I got the garage door hooked in, using the guest network (nothing else would work).
But my Echos will not all join the "everywhere" group, and the problem seems to be the 5ghz vs. 2.4ghz conflict. A wireless printer had the same issue, though I resolved that in a way that eludes me. Don't care, it works now.
But is there a way to either TURN OFF 5ghz, or split it so that the Echos don't try to join different bands? My understanding was that devices pick the thing that they work with automatically. This has not been my experience.
Thanks in advance for any help. It's driving me up the wall. --Jamie in Reynoldsburg.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Separating or Disabling 5Ghz and 2.4Ghz on Mesh WiFi 6 System
Hello JamesterReyburg,
The Nighthawk Mesh system currently does not support the feature of separating the 2.4Ghz and 5Ghz bands.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. Any ideas for Amazon Echo devices that just won't play nice? It's maddening, especially since it used to work just fine. . . Thanks again. --Jamie
- Mark as New
- Bookmark
- Subscribe
- Permalink
I really am lost, and could use a suggestion (even if it is admitting that my Nighthawk mesh system was an expensive mistake. I've got problems with smart switches that once worked, that no longer want to. Inconsistent connections with my echo devices. The garage door set up was torture. And it all seems to be centered around the 5Ghz/2.4Ghz problem. There is NO WAY to address this with this system? Thanks for your initial answer, but what do OTHER people do in this situation? Thank you. --Jamie
