Orbi WiFi 7 RBE973
Reply
Trying to use wifi6e on RAX 50
Retired_Member
Not applicable
Now I have an iPhone 14 pro which should support this protocol. It seems as though I need WPA3 and I have a ton of older Ring, Chamberlain, Hue, computers and tablets that won't support WPA3. If I set to WPA3 will smart connect automatically back down the protocol OR do I need to set a separate SSID for the phone alone?
Message 1 of 8
Accepted Solutions
Guru
Re: Trying to use wifi6e on RAX 50
If you have other devices that don't support WPA3 then you'll need to keep with WPA2 and AES. I don't know if this model has a mixed WPA2 and WPA3 setting.
6E is a 6Ghz frequency which this model router doesn't support.
Message 4 of 8
All Replies
Guru
The RAX50 doesn't support 6E only 6.
Did you find security mode settings under Basic tab/Wireless settings?
Message 2 of 8
Retired_Member
Not applicable
Yes I see those settings but I do now want to lose all of my devices that cannot use that protocol. I have it set to enable AX though.
Message 3 of 8
Guru
Message 4 of 8
Retired_Member
Not applicable
So assuming I need WPA3 to connect to AX I am out of luck so to speak.
Message 5 of 8
Guru
No, AX works on WPA2 or WPA3.
Ya no mixed mode WPA2 and WPA3 so you'll need to keep with WPA2. Or find you a router that supports mixed modes.
Message 6 of 8
Retired_Member
Not applicable
And now that I know this new phone doesn't support 6e as well, I should be satisfied with my 225 meg download speed. Since I have 1gig speed here I was looking for more. I am hesitant about any mesh system because of ODNT* So I will wait for next years iPhone upgrade and see where that takes me.
* ODNT (you can't teach an old dog new tricks)
Message 7 of 8
Guru
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1738 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
