× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Unable to load latest firmware on RAX80
jelsomino
Tutor
Hi,
Can't fine similar post so I'll create a new one. I checked firmware update for my RAX80 router and automatic system found a new 1.0.5.126 version (see attached)
However when I tried to use Firmware Update Assitant, it stuck on "GUI Language Update Downloading and updating the language table, please wait for approximately one minute…"  and does not proceed further. Also I'm don't see this version on RAX80 page, where 1.0.4.120 is listed as latest
Is there a way to either install it using Update Assistan or download new firmware directly?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 6
Accepted Solutions
jelsomino
Tutor
Re: Unable to load latest firmware on RAX80
Thank for the suggestion but there is no new firmware file to download.
P.S. Problem solved by restarting the router and attempt to update using Nighthawk app for Android
Message 3 of 6
All Replies
Guru
I would try manually updating.
I prefer this method anyway as a manual update over a hardwired connection tends to get the least "corrupt firmware" issues.
Message 2 of 6
jelsomino
Tutor
Message 3 of 6
Guru
Eitherway, glad to hear you were able to update successfully
Message 4 of 6
daweidu
Star
New Firmware Version1.0.5.126_1.0.65
Release Notes:
 1.   [Bug Fixes] Fixes minor bugs.
 2.   [Security Fixes] This firmware fixes security vulnerability issues. For more information about security vulnerabilities, visit netgear
Message 5 of 6
yashago
Guide
@jelsomino Thanks for bringing this up. I encountered same issue.
Firmware update thru the android app worked.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3854 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
