Brancy51's avatar
Brancy51
When I use my Nighthawk app, it shows my router as "offline" connected locally". But I can search
When I use my Nighthawk app, it shows my router as "offline" connected locally". But I can search and use the web fine.
    • Brancy51's avatar
      Brancy51
      I'm connecting the Nighthawk router to an Arris TM1602 modem supplied by Optimum in New Jersey.  I have done nothing special.  I just connected the router to the modem.
    • Brancy51's avatar
      Brancy51
      I'm not sure what this issue impacts, but I'm having trouble with Hulu, Netflix and Amazon Prime.  My guess is these services are confused by some change caused by the new router. I previously had an Optimum router.  I think the issues with Hulu, Neflix and Amazon Prime will resolve by reinstalling the apps, unplugging the tv and waiting about a day.  The problem is every time you have an issue, you have to wonder about the odd status on the router.
      • plemans's avatar
        What firmware is on the router?
        Are you using IPv4 or IPv6?
        Have you tried a different dns provider? you can try googles at 8.8.8.8 or 8.8.4.4 or cloudfare at 1.1.1.1
        are you using any parental controls?
        Any other managed switches, routers connected on the network?
  • michaelkenward's avatar
    michaelkenward
    What says ofline and where?
    It may may be that you are offline from Mynetgear, the Internet "tunnel"  that connects you to Remote access on the router.
    Then there is the possibility that it is something like ReadyCloud.
    This is all just theory in my part based on the lack information and the many different possible causes of these symptoms.
    • Brancy51's avatar
      Brancy51
      The message was in the top right corner of the router screen on the iPad Negear App.  Unfortunately, I couldn't let me household go without a solution for days.  Right now, the Nighthawk is collecting dust in the attic.  And Optimum's deceptive sales tactic has disrupted my Plan A.  Altice said they would just give me a wireless cable box.  Instead they showed up with a new combined router/modem.  I'll see how this works.  Maybe I'll try to setup Nighthawk as a secondary router.
      I appreciate the help, but we're not going to be able chase this one down to resolution.
        michaelkenward
        That won't work. You need tp put the Nighthawk thing into wireless access point mode. Or work out how to bypass (bridge) the new modem/router from your ISP.
