× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Why I am having problems with an NVMe SSD USB enclosure hanging off the RAXE500 USB port?
Compumind
Tutor
Hi all -
Using a portable HDD presents no issues. However, I have a Sabrent NVMe USB 3.1 enclosure that has a 2TB NVMe in it.
Then it is connected via a standard USB cable to the back of the RAXE500 and I'm able to see it as a shared drive,
The NVMe is formatted for NTFS (also tried exFAT) and I am getting various I/O errors when copying files to the drive.
I suspect that there might be an incompatibility with the Sabrent enclosure and translation chip within the enclosure itself.
Has any one managed to seamlessly connect an SSD (not a flash stick) to the RAXE500?
The SSD  works fine under W10/W11 but I believe that the RAXE500 is running a Linux derivative.
So there are a few variables here, to say the least.
Thanks.
Message 1 of 5
Re: Why I am having problems with an NVMe SSD USB enclosure hanging off the RAXE500 USB port?
Good luck.
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
I have no idea if your drive would hit the dreaded SMB issue:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
Message 2 of 5
Guru
the router doesn't install drivers so if the nvme drive or enclosure needs one, it'll create issues
Message 3 of 5
Yes, but if Windows needs drivers, like many other USB devices, once installed shouldn't the thing work on the network?
Isn't that a red herring?
Message 4 of 5
Compumind
Tutor
Netgear did not think this through, amongst other things.
If they request some technical information form me, I'll gladly provide it.
Poor USB implementation.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1300 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
