× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Wi fi wont connect on setup
Timbree
Follower
All of my lights are green except for the one that I believe is wifi and it is amber colored what do I do.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
Guru
Re: Wi fi wont connect on setup
You say wifi won't connect.
Did you set it up?
do devices that are hardwired into the router work?
Have you tried logging into the router to change/setup the wifi ssid/password?
Is it all devices or just one?
"All of my lights are green except for the one that I believe is wifi and it is amber colored what do I do."
You "believe its wifi" and its amber? here's the link to the support site with firmware, troubleshooting, and a manual that walks you through the led's and what it means for color/blinking.  I'd take a look through it so we can better understand what light it is and the issues.
https://www.netgear.com/support/product/rax40
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 862 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
