× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
bug report: firmware 1.0.4.102 for RAX40 doesn't allow ssid/password to be changed
dwaynek
the latest firmware 1.0.4.102 won't allow me to change ssid/wifi passwords even after repeated resets.
I finally rolled back to a previous version which works fine.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 3
Guru
Re: bug report: firmware 1.0.4.102 for RAX40 doesn't allow ssid/password to be changed
Did you factory reset the router and setup from scratch after v.102 was loaded?
Message 2 of 3
回复: bug report: firmware 1.0.4.102 for RAX40 doesn't allow ssid/password to be changed
Hi @dwaynek ,
Did you use GUI or Nighthawk APP to config the Wi-Fi setting ?
If you used Nighthawk APP, which app version did you use ? iOS or Android ?
Thanks.
Message 3 of 3
Discussion stats
  • 2 replies
  • 911 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
