× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
i have the modem router c3000 , can i hook my nighthawk ax3000 to be the primary router?
jetsetser
Follower
trying to hook my night hawk ax3000 to my modem router combo netgear c3000. help!
Message 1 of 3
Guru
Re: i have the modem router c3000 , can i hook my nighthawk ax3000 to be the primary router?
you can put the C3000 in modem only mode.
This allows you to use the AX3000 as primary router.
Message 2 of 3
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Read the bit To cable your modem router to a router or gateway.
Message 3 of 3
Discussion stats
  • 2 replies
  • 600 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
