× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
wall mounting AX11000 RAX200 (Imperial Shuttle Special Edition) orienttion
WaldoTrout
Follower
All the guides say and show antenna positioning as vertically.
then comes the "Imperial Shuttle" editions of the routers.  (AX11000, AX6000, e.g. although my NetGear APP displays the router as "RAX200")
if i need to mount this on the wall, the mounting holes imply that the antennae will be pointing out directly into the room, away from the wall.
is this really a recommended orientation?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 8
Guru
Re: wall mounting AX11000 RAX200 (Imperial Shuttle Special Edition) orienttion
Most routers these days have omnidirectional antenna's in them. doesn't mean there isn't a bit of optimal positioning as they tend to work better horizontal (broadcast covers a floor level). Placing it veritally might impact it enough to change that. All you can do is try it.
I wall mounted my RAX200 and it works fine but I also have an orbi setup providing the majority of my coverage because I've always had dead spots in my home.
Message 2 of 8
npugyp0k
Could you please elaborate on your setup (RAX200+Orbi)?
I've just bought a RAX200 and really wanna hang it on the wall, however, if that impairs it's performance i'm gonna tabletop it. On the other hand I don't mind picking up Orbi as well. Your input is much appreciated.
Message 3 of 8
Guru
you can see how i have mine setup in my signature
Message 4 of 8
npugyp0k
Oh, I see, so your RAX200 and Orbi are hooked up to the switch and work independently from each other. Cool, thx!
Message 5 of 8
Guru
My orbi is in AP mode. So its going RAX----->switch------->orbi------->satellites.
Message 6 of 8
npugyp0k
So RAX is not broadcasting a network...??
Message 7 of 8
Guru
It is but mainly for testing purposes. My house doesn't get good enough coverage off 1 router and mesh supplies the best overal connection.
Plus running the RAX gets me familar with the AX devices/usage/scenarios. Its a bit overkill
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3102 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
