× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
will orbi 6E work with nighthawk AX12?
sgau
Tutor
will orbi 6E work with nighthawk AX12 Wifi Router?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Guru
Re: will orbi 6E work with nighthawk AX12?
As far as?
Depends, What are you using for your host router? Orbi or RAX?
Orbi has both 5 adn 6Ghz frequencies where the RAX only as 5Ghz.
If you set up the RAX as a client in bridge mode it will connect to the Orbi system, just only connect on 5Ghz.
The RAX will not integrate into the Orbi MESH system.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 593 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
