× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
My new RS700s packet loss
Hambaka
Hello, i replaced my existing AC router with new RS700s router.
the speed is incredible higher through Ookla speed test.
but i saw the that there is always packet loss. ( never happend with my old router )
the loss ranges between 2% and 10%. Can someone explain the reason? The test was done near the router with no obstacles.
in addition to that, the upload speed is lower than the previous AC router (
i used to get 200-300 upload speed and 300~400 download speed )
Message 1 of 4
ShadowMario3
Luminary
Re: My new RS700s packet loss
Definitely doesn't seem to be normal. On ethernet (Windows 11, using the Speedtest app for Windows) and 6GHz wi-fi (Pixel 7 Pro, Speedtest app), I have 0% packet loss. Did you make sure that you are on the latest firmware?
Message 2 of 4
Hambaka
yes, i updates the router to the latest firmware version.
i tried also to check through my iphone, i got 8% packet loss.
i checked the ethernet cable ( high quality cat 8 and cat 6A cables ) and same issue.
when i reinstalled my old router i am getting 0% loss.
So i believe its something with the router itself.
what would be the solution/how to troubleshoot? Which settings should i check? I purchased my router few weeks ago.
Message 3 of 4
MonsterKody
Do you have QoS enabled?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 816 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
