Oct 28, 2024Guru - Experienced User
New - RS150, RS280, RS300, RS500 and RS600 firmware Version 1.0.1.60 Released
Enhancements: 10/23/2024
- Fixes multiple other minor bugs
- Adds Advanced Router Protection function. (RS300, RS500 and RS600 series only.)
Download Links:
RS150: https://kb.netgear.com/000066380/RS150-Firmware-Version-1-0-1-60
RS280: https://kb.netgear.com/000066369/RS280S-Firmware-Version-1-0-1-60
RS300: https://kb.netgear.com/000066370/RS300-Firmware-Version-1-0-1-60
RS500: https://kb.netgear.com/000066366/RS500-Firmware-Version-1-0-1-60
RS600: https://kb.netgear.com/000066367/RS600-Firmware-Version-1-0-1-60
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button.
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a >factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here:
This article applies to:
Let us know how it works for you...
Turn it OFF.
- matemikTutor
Since update V1.0.1.60, whenever i restart the router, i can't get any WiFi working in any band.
In order to get it working properly i need to acces the interface via browser and disable, then re enable vlan/bridge at every power cycle (my ISP do require it to get the connection working). Everything was working perfectly with the older firmware 1.0.0.38.
- matemikTutor
Yes, I tried a factory reset and also tried to rollback to the old firmware. Then I upgraded again to the latest, and performed the reset again but nothing worked for me.
Is there a new firmware coming soon that fixes the restart issue for the RS600? I'm currently on a test beta since December and have noticed speed drops so just curious if there's a stable one in the near future.
