Orbi WiFi 7 RBE973
Reply
Port Forwarding on RS700
ALNiKO
Hi all!
I received my RS700 several days ago and I'm pretty happy with Wi-Fi speeds, coverage and setup. However, I'm struggling to get port forwarding to work. I have Pace 5268AC modem/router from AT&T and RS700 in DMZ Plus mode. AT&T's network is 192.168.1.0/24 and RS700's 10.0.0.0/24. I have some services running on my network and one of them is listening on port 7809 - when I navigate to 10.0.0.200:7809 in my web browser I can access the service. As soon as I enable port forwarding on RS700, I can no longer access this service either by using local IP or external IP from inside of my network (my computer's IP is 10.0.0.10). However, I can access this service via external IP from outside of my network. The interesting thing is I can telnet into port 7809 either by using internal or external IP, but I can't access this IP via the web interface. I tried enabling/disabling Armor on RS700 as well as settings in WAN Setup (Disable Port Scan and DoS Protection, IGMP Proxying, NAT Filtering (Secured, Open)) to no avail. My previous Netgear router (R8500) worked fine with the same home network config and ISP's equipment. I tried running Wireshark and all I'm seeing is TCP Retransmission and TCP Spurious Retransmission messages when port forwarding is enabled. UPNP is disabled.
Any help would be greatly appreciated
Message 1 of 32
Accepted Solutions
BH-C
NETGEAR Expert
Re: Port Forwarding on RS700
Hi ALNiKO,
Thank you for working with us offline. As you have confirmed the tiral firmware has fixed the issue, and we will include the fix in a maintenance release, which we expect to happen later this year.
Message 4 of 32
All Replies
BH-C
NETGEAR Expert
Hi ALNiKO,
I would like to make sure I understand your issue correclty, is this description correct?
* When the Port Forwarding rule is disabled
  - local computer 10.0.0.10 can access http://10.0.0.20:7809 and http://<external IP>:7089 (or https?)
  - local computer 10.0.0.10 cannot access http://10.0.0.20:7809 or http://<external IP>:7089.
  - But the lcoal computer 10.0.0.10 can access
      > telnet 10.0.0.10 7089
      > telnet <external IP> 7089
  - And an external computer can access http://<external IP>:7089.
Thanks.
Message 2 of 32
ALNiKO
Hi!
* When the Port Forwarding rule is enabled
This is correct.
Message 3 of 32
BH-C
NETGEAR Expert
Hi ALNiKO,
Message 4 of 32
I was just losing my mind trying to figure out what was wrong with my server, what a huge oversight. Can I get the new firmware as well?
Thank you,
Message 5 of 32
BH-C
NETGEAR Expert
Sorry about the trouble, we will pass you the trial firmware offline. Thanks.
Message 6 of 32
The link you provided in the DM did not work, someone called me from netgear and sent me a new link to RS700-V1.0.7.68_2.0.74 this firmware solved the issue.
Message 7 of 32
BH-C
NETGEAR Expert
Thanks for the confirmation. v1.0.7.68_2.0.74 is the correct trial firmware version.
Message 8 of 32
mrjoshuaco
I'd like to get a copy of this firmware myself, as I'm also experiencing the same issue. Thanks in advance.
Message 9 of 32
BH-C
NETGEAR Expert
I've sent you the link through PM. Thanks.
Message 10 of 32
Retired_Member
Not applicable
I would like it for the rs700s as well, please.
Message 11 of 32
BH-C
NETGEAR Expert
OK, sent. Thanks.
Message 12 of 32
Jeffw0ng
It seems that I have the same issue, could you also send me a copy of the firmware as well?
Message 13 of 32
FooF
I would like firmware RS700-V1.0.7.68_2.0.74 as well thanks
Will this work on rs700s?
Message 14 of 32
BH-C
NETGEAR Expert
Hi @Jeffw0ng @FooF,
I've sent you the link for the tiral firmware through a Private Message, please check it.
This firmware works for RS700 and RS700S; they use the same firmware.
Thanks.
Message 15 of 32
FooF
I tried going to the link and it is asking me for auth and none of my accounts have access
Message 16 of 32
FooF
thanks new link worked
Message 17 of 32
WestSider
Hello,
I have a similar issue that is happening with a NVR server for local use as well as a security team for after business hours that would monitor remotely. The firmware addressed the port forwarding issue but now when the remote users access the Live video feed it is very choppy, losses connection, or buffers continuously. After the firmware was installed I did a factory reset and reconfigured as well, any tips for this?
I also have tried other Netgear Wi-Fi routers with no issues on that hardware.
Thanks,
Message 18 of 32
Guru
Ask the forum moderator for the beta FW file.
@BH-C
Message 19 of 32
WestSider
Hey FURRYe38,
Thanks, I'll ask,
Currently using Firmware Version : V1.0.7.68_2.0.74
Message 20 of 32
Intoxicating
Guide
Hi @BH-C
Could I also get the firmware please?
Thanks
Message 21 of 32
BSTPVA
Sorry to add to the spam in the thread. I'm also trying to find that firmware sadly. Can't seem to find it anywhere online.
Message 22 of 32
BH-C
NETGEAR Expert
Hi Intoxicating / BSTPVA,
I've sent you PM with the link to the firmware.
Message 23 of 32
KThiel
Tutor
I'm sorry to jump on the train....but I also need the firmware please
Message 24 of 32
BH-C
NETGEAR Expert
OK, firmware sent through PM.
Message 25 of 32
Discussion stats
  • 31 replies
  • 13526 views
  • 3 kudos
  • 15 in conversation
Announcements
Orbi 770 Series
