× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
RS700 ethernet port issues
Rhubbard97
As it says in the description, my ethernet ports are giving me trouble.
I bought this router back in May and it has worked great until recently. Every morning when I turn on my work computer, connected to ethernet, it will not connect to internet regardless of which port I use. The port illuminates and is white, showing a strong internet signal, but my computet shows network connected, no internet.
The wi-fi network has always workes well and never shows issue. Even when the ethernet is causing problems I still get a strong connection across the wi-fi network.
This is not an issue with my work computer, it happens on my personal computer which is also connected to ethernet as well.
If I reboot my router it will allow my ethernet connected devices to connect to the internet, and they will stay connected throughout the day, but I have to do this every single time I power on one of those devices.
I have checked and am using the latest firmware as of 8/8/2024
v1.0.7.86
Any help with this would be greatly appreciated.
Message 1 of 9
Guru
Re: RS700 ethernet port issues
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What brand and model# are these ethernet connected PCs and devices?
What brand and model# are the ethernet adapters in the PCs?
Ensure any ethernet adapter driver in PCs is updated from it's Mfr.
What CAT# LAN cable are you using between the router and ethernet connected devices? CAT6 is recommended. If your using a high speed ethernet adapter at the PC, 2.5Gb or beyond, then CAT6A STP is recommended.
Message 2 of 9
Rhubbard97
My isp, Comcast, provided me with an XB8-T modem.
The ethernet cable is from Orbram, RJ45 flat cable Cat 8.
1st device: Dell latitude 5501
Ethernet adapter: intel I219-LM ethernet 802.3
2nd device: custom built windows PC
No factory reset has been attempted.
Message 3 of 9
Guru
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS8...
Try option #2 first...
Please change out the flat CAT8 cable for a thicker CAT6A STP cable between the ISP modem and the RS WAN port.
Ensure the ethernet adapter drivers are using most current driver from Intel.
Might factory reset the RS and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
Message 4 of 9
Rhubbard97
My ISP modem has been set in bridge mode since purchase and I would not blame the cables either. I can verify that I am getting strong internet from them.
My ethernet drivers are up to date.
Is a factory reset your only suggestion?
Message 5 of 9
Guru
Yes. If after that the problem still happens, you'll need to contact NG support and open up a support ticket.
Message 6 of 9
DarrenM
Sr. NETGEAR Moderator
Have you ever contacted support, or do you still need help with this issue?
Message 7 of 9
Rhubbard97
I reached out to support this morning and still have not heard back.
Message 8 of 9
DarrenM
Can you Pm me your case number I will escalate the issue.
Thanks
DarrenM
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1574 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
