Orbi WiFi 7 RBE973
Reply
Connection-to-AirPort-Express-from-RBK752-Orbi-WiFi-6
SoonerOne
Tutor
I am considering purchasing the RBK752 Orbi WiFi Router Mesh system.I cannot fing any information concerning the possibility of connecting Airport Expresses to the Orbi System. Is that possible?
Thank you.
Message 1 of 6
Guru
Re: Connection-to-AirPort-Express-from-RBK752-Orbi-WiFi-6
Most Orbi systems are backwards compatible.
Orbi Supports wireless modes:
Orbi AX4200 Router and AX4200 Satellite
(600 + 1200 + 2400Mbps)†
• Simultaneous Tri-band WiFi
- Radio 1: IEEE®
802.11b/g/n/ax
2.4GHz—1024-QAM support
- Radio 2: IEEE®
802.11a/n/ac/ax
5GHz—1024-QAM support
- Radio 3: IEEE®
802.11a/n/ac/ax
https://www.netgear.com/images/datasheet/orbi/RBK752.pdf
Review the support and wireless modes of your AEs to see what modes they support. Contact Apple support for further information regarding this.
Message 2 of 6
ekhalil
Master
I have my Airport Time Capsule (ATC) wired to Orbi in AP mode. I think you can easily the same setup in AE.
Message 3 of 6
Guru
If you want the AE connected wirelessly, I would recommend that if you get the Orbi AX system in, configure the RBR to use the same SSID name and password as you are currently using on your current wifi router. Then once you get the Orbi AX system online, migration with your wifi devices should be seemless and they should all connect to the Orbi AX system. You may need to reboot your wifi devices.
Message 4 of 6
SoonerOne
Tutor
Thank you for your excellent information. I appreciate your help!
Message 5 of 6
Guru
Good Luck.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1000 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
