Orbi WiFi 7 RBE973
Reply
Constant problems with WiFi 6 RBK852
JamesAstroB
Initiate
I just upgraded to the Orbi RBK852 WiFi 6 model, and now I'm having a huge number of problems:
• My HP printer is offline, and won't join the WiFi network. I tried resetting its network settings, and that didn't help.
• My Netatmo cameras frequently disconnect and reconnect. I measured the signal strength at each camera, and they all receive a signal that is -55db or better. That's a strong signal, but the cameras still have problems.
• My ecobee thermostats frequently don't respond to Siri commands. Just like the cameras above, the ecobees all have very strong WiFi signals.
• Several of my Lutron Caseta automations no longer work. My Lutron hub is only a few feet from the Orbi router, so I'm not sure why this would happen.
• The Orbi App and OrbiLogin web page show no devices. I have about 50 WiFi devices, and they are all online (except for the issues mentioned earlier.) However, the device list is empty.
Has anyone else seen this epic level of failures? I'm thinking I may need to return this, and go back to my Velop WiFi 5 system.  😞
Message 1 of 5
Guru
Re: Constant problems with WiFi 6 RBK852
Please post about this over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
Message 2 of 5
JamesAstroB
Initiate
Thank you for the suggestion. I just reposted this in the other forum.
Message 3 of 5
Guru
Good Luck.
Message 4 of 5
Guru
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2346. Reboot both RBR and wireless devices. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1245 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
