Orbi WiFi 7 RBE973
Reply
Orbi WiFi 6 System (RBK752) AX4200
718humanoid
Want to know if this can be used with optimum
Message 1 of 5
Guru
Re: Orbi WiFi 6 System (RBK752) AX4200
Please post about this in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Message 2 of 5
Guru
Orbi can be used with any ISP service. Though the modem used needs to be looked at. Stand alone modems are preferred, with out a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
If a modem with built in router is in use,
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Some ISPs support user owned modems. Review ISP information on what they support first before buying your own modem.
Message 3 of 5
718humanoid
Thanks for the advise. Last question for a 1 gig optimum plan what modem do you suggest
Message 4 of 5
Guru
IF they support cable modems, then NGs CM1000, 1100 are my first recommendations.
If they don't see if they surpport Arris SB8200 or Motorola MB8600 modems.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1237 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
