Orbi WiFi 7 RBE973
Reply
RBK852: Speed at 5GHz 801.22ac
Michek
Hi!
What maximum speed does the Orbi RBK852 kit support at 5GHz 801.22ac?
I read in an Amazon review that the maximum speed supported at 5GHz 801.22ac is 867 Mbps. Is that correct?
Many thanks in advance!
Michek
Message 1 of 4
Guru
Re: RBK852: Speed at 5GHz 801.22ac
Orbi AX6000 Router and AX6000 Satellite (2400 + 2400 + 1200Mbps)†
https://www.netgear.com/images/datasheet/orbi/RBK852.pdf
Message 2 of 4
Michek
Hi FURRYe38!
Thanks for your reply!
Maybe I'm too stupid to understand this, but where can I find out how fast the system works in this environment?
Thanks!
Michek
Message 3 of 4
Guru
A few factors, connected wifi devices like phones and pads, etc don't all have same support for max speed rates.
Have to check with Manufacturers for this information.
WiFi Sweet Spots is a good app to see connection rates with a phone or pad while connected near a RBS or RBR.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 665 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
