Orbi WiFi 7 RBE973
Reply
RBR850 not connecting to Logitech Squeezebox
Coffeecup
Star
I just upgraded from the RBR50 to the RBR852 and now my Squezzebox cant connect to my WiFi.  Any ideas or suggestions?  Thanks
Message 1 of 6
Accepted Solutions
Guru
Re: RBR850 not connecting to Logitech Squeezebox
Remove the check mark from the 2.4 and or 5Ghz check boxes. Apply the change.
Message 4 of 6
All Replies
Guru
Try disabling AX mode on the RBR.
Try setting CTS values to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 6
Coffeecup
Star
Sorry, but how do I disable AX mode?
Message 3 of 6
Guru
Message 4 of 6
Coffeecup
Star
Thanks FURRYe all is good in SqueezeBox land!
Message 5 of 6
Guru
Awesome. Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 975 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
