- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
robi 753 router in AP mode connected to a GBE switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
this seems like a supported method - modem router to a GBE switch and the Orbi conected to one of hte ports of the Gbe switch.
used on this manner the speedtest function within the orbi app does not work - it say no connection while the Speedtest IOS app works just fine and i have connections to the wifi clients on the ORbi.
further in this mode with the XFi wifi also working i keep seeing in the connected devices on the XFI network whow up as wired devices on the orbi
any ideas?
i also had a support person tell me that the Orbi cannot be connected to the port of a GBe switch but must be connected directly to the modem router ethernet port? anyone can corroborate that?
thanks for any and all help!!
best
NM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: robi 753 router in AP mode connected to a GBE switch
What modem/gateway are you using?
What switch are you using?
Is your orbi the RBk753?
How exactly is it wired:
for example: modem model*---->switch----->router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the topology is xfinity arris 1862L modem router connected to a 16 port TrendNet unmanaged Gbe switch. That switch is connected to rj45s thru out the house and the Orbi753 router is connected to the switch in the study.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@snakeking2 wrote:
Thank you!
Sometimes having a switch between the ISP modem and Orbi causes issues. You are better off connecting the orbi directly to your Arris modem/router, then the switch. Then if you have satellites you can connect them to the switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd agree with what @Mstrbig says and going
modem/gateway-----orbi router---switch---satellites.
I've done it both ways. (modem/router----switch----orbi router)
Satellites
the only time I've found that everything works fine is if the satellites are all wireless. If they're not, then you need the switch after the orbi router for the app/connected devices lists to function properly
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to post over in the Orbi AX Forum for you future needs:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now it’s interesting to know that backhail could be GBe or WiFi. And down link? Ie Does the satellite still need to be within “blue light Distance “ from the orbi router AP or no?
Latest anyone have experience running to WiFi’s since Xfinity apparently does NOT allow
Me to turn off their WiFi! 😡 so then while I’ll rename the ssid I suspect there will still be interference from that to the orbi net
- Mark as New
- Bookmark
- Subscribe
- Permalink
When ethernet connected the up and downlink data is passed over the ethernet wire connection.
No you can have the RBS out at a much greater distance from the RBR as the connection is wired which no long depends on distance in between. Only the length of the wire will determine the distance.
