Orbi WiFi 7 RBE973
Reply
Any way to bypass Armor signup when logging in?
RockTheGlobe
Guide
While I have the Orbi app downloaded to my iPad and iPhone, I've avoided using it for the past several months because every time I open it, I can't get past the splash screen where it asks me to agree to a trial of Netgear Armor before it will let me use the app.  Am I missing something?  Is it possible to get past this screen without signing up for Armor, or do I have to activate it in order to use the app and then figure out how to immediately cancel?
Message 1 of 3
Guru
Re: Any way to bypass Armor signup when logging in?
No there isn't without activating that I know of.
Annoys the crap out of me too.
there should be a check mark to "never ask me again" type thing
Message 2 of 3
Guru
I wish there was a (X) button.
I guess activate it then you can disable it under Settings/Security with in the NH app.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 348 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
